sway bar link easy to repair, mega squirt ?
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
clarkandrew45
- Year and Model: 2008 Volvo S60
I did and tried that one mate, not an easy thing to do for me. I guess its because i am really not familiar with it. Thanks for sharing this mate, this would be a great help for me.IVIUSTANG wrote:Sway bar links are easy for anyone with a jack, requires two bolts to be removed. If you jack your car in the centre of the sub frame(so you lift both front tires) it should put even pressure on the sway bar so you can do it with one jack. Most recommend doing both end links, as a broken one can put excess pressure on the other side causing wear. It MAY be possible you need to have an extra jack to load either the spring or sway bar to line up the bolt holes, I have never needed to.
As for your fuel economy, 20/25 US MPG is in a typical range I would say.
- Jesse
- Been thanked: 504 times
My endlink just broken on pass side.
Is it safe to drive for a few days (i.e. does the lower broken end poke on anything at all?) until I get the parts in?
- dosbricks
- Year and Model: '96 855, '98 S70
- Been thanked: 4 times
I assume you are talking about the link itself? Maybe.... but unknown. How about turning the wheel all the way to the left, reach in and disconnect it at the strut with a long-handle flex-head ratchet and deep socket. Clamp a vise grip on the back side of the stud for counter-grip since the link is toast anyway.cn90 wrote:My endlink just broken on pass side.
I actually keep a spare link in my parts bin (which has insured that I've never needed it).
- Has thanked: 311 times
- Been thanked: 817 times
If you are at all unsure, how about just remove the broken part, that's a super easy one to get off.cn90 wrote:My endlink just broken on pass side.
Take them both off if you have time but it will be fine for a little bit with only one link if you go easy on the driving.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
People drive with.them broken all the time. I would suggest removing it.
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
I am a strong -1 on the IPD heavy duty sway bar end links. I never had a Volvo oem link break on me, but I did have an IPD "heavy duty" link go bad on me. Search for my thread on the topic. Also, as was pointed out in the post I am referring to, IPD used to warranty their heavy duty links for 5 years. Now it is a one year warranty. Suggests they may know something about the quality of their heavy duty links that the aren't telling us about.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- regent
- Has thanked: 2 times
- Been thanked: 12 times
OEM or MeyleHD links are fine; IPD's with reduced warranty do not sound that convincing
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
I have a seized endlink screw (the lower bolt that meets the sway bar, not the top part at strut). I have been tried to get it off for 6 months! The boot is ripped off, but the joint is still pliable. I am thinking about just cutting it off, tried impact and flare nut wrench.
I love how some jobs take at least 2 or 3 tries/days
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
'97 855 N/A
- 34 Replies
- 9347 Views
Last post by E Showell
- 855 Views
Last post by FCPEURO
- 1446 Views
- 2314 Views
Last post by theWIFES_S70
- 14 Replies
- 3396 Views
Last post by subzerocarfanatic
