Thanks.. I was mostly concerned about full synth possibly causing my seals to leak. I don't have much history on this car... The po has no idea when the odometer stopped working...ecbsykes wrote:I would at least go with semi-synth on a turbo. If you do any hard driving at all, that turbo gets a lot of heat which can really fry oil that isn't meant for the application. If you want to use dino oil in your turbo, at least use a xW-40.thecheat wrote:Don't know what the previous owner used for oil, should i go semi synthetic or regular dino juice on my turbo when i change the oil?
If you don't want to shell out the money for a synthetic, I'd recommend Castrol Syntec Blend for a "blend" oil.
But if you want a "clean" engine, Pennzoil is known to be very effective at cleaning deposits in many engines, especially their Platinum synthetic which can usually be found on sale at Walmart for $20/5 quarts.
auto zone brand oil
thecheat
- Year and Model: 1996 850 Turbo Wagon
