Starter relay?
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
oldschoolvolvo wrote:awesome! thank you!
Please post an update what you find.
oldschoolvolvo
Year and Model: 1979 242DL
Has thanked: 1 time
Post by oldschoolvolvo »
it's not a common occurrence, but typically happens when there is a sharp change in the weather, another reason for me to suspect moisture is getting into the relay. i'll pull the relay at some point to look at it, but for some reason was under the impression that my car didn't have a starter relay??
-Mike
Current:
1979 242 DL
1998 V70 T5
1992 240 GL
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
I'd suggest starting simple and beginning at the beginning. Ignition switch.
It's a part of the car that gets used every time you drive and does wear out.
From there, run down the circuit towards the starter. It's all in the diagrams.
luckykolo
Year and Model: s70 1998 Base
Has thanked: 14 times
Post by luckykolo »
Hi, anyone has a starter's relay diagram explaining which contact is connecting to what and voltages passing through? Thanks
