Check Engine Light!
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Re: Check Engine Light!
Post by misha »
pauleads wrote:Would failure of this pump lessen gas mileage or cause other problems if left like it is?
The failure of the air pump itself will not affect fuel consumption BUT stuck open SAS valve WILL because it will produce a vacuum leak at it's vacuum line.When it fails...it always fails in open position.
Usually,sas valve is the first one which fails in that circuit and lets water from condensation directly into air pump and after that...from air pump through air filter and MAf...into engine.
If your sas valve is stuck in open position,air pump is not the only thing which will fail because of that.Maf is also in danger.
My suggestion is to search for "sas delete" on this forum.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
charleskennedy23 wrote:Rumor has it there is a way to bypass the SAS system altogether
http://volvospeed.com/vs_forum/topic/14 ... with-pics/
85 GLH, 367 whp
00 Insight, 72 mpg
