Nasty Engine
Groatie-da-kid
Year and Model: 1999 s80 t6
Post by Groatie-da-kid »
on my t6 wreck rebuild, i used engine brite gel, a die grinder wire wheel, vulcan blasted my intake, let the gel sit for twenty minutes on the whole motor and under carriage minus the turbo and alternator. Cleaned light grime with a scotch brite, then used the die grinder to clean scale and heavy build up, washed with light pressure water and blew it off with an airgun. the n painted my intake valve cover and face of the head with gloss black engine enamel, then i scuffed and painted the timing belt and spark plug cover volvo code 339 torch red metallic base clear. then wiped it down with a body shop safe cleaner.
wrecked clean title 500 bones
all back together
all back together
how she looked yesterday
pre assembly
pre assembly
1999 s80 t6 rebuild, 1969 gto 4spdRA3, 1982 f-350 diesel custom chassis, 94 bronco beater, and i cant legally buy booze. :)
dbm123
Year and Model: 1999 V70 GLT
Post by dbm123 »
vjaneczko wrote: To make it really look good afterwards, spray it down with a 50/50 mix of water & Armor All and let it air dry. Looks pretty sweet, especially the plastic and rubber.
Interesting idea. Any downside to doing this?
Current Volvos:
2004 C70 HPT (wife)
2002 S40 1.9T (daughter)
2001 V70 XC (daughter)
1999 V70 GLT (now dead)
1998 V70 GLT (son)
The other car: 2003 Saab 9-3 SE Convertible (mine)
vjaneczko
Year and Model: 2006 S60R
Been thanked: 7 times
Post by vjaneczko »
Not that I know of. I'd avoid spraying any of the metalic stuff but since it's a 50/50 mix, it's not going to be a huge problem.
1997 855 GLT - R.I.P.
2006 S60R - For ME!
dbm123
Post by dbm123 »
vjaneczko wrote:Not that I know of. I'd avoid spraying any of the metalic stuff but since it's a 50/50 mix, it's not going to be a huge problem.
OK... it works. I just got started, but this is the result so far.
[img]
[/img]
Current Volvos:
2004 C70 HPT (wife)
1998 V70 GLT (son)
vjaneczko
Post by vjaneczko »
Nice Job! Looks like you even rubbed the firewall heatshield with a rag to buff it up a bit?
2006 S60R - For ME!
dbm123
Post by dbm123 »
vjaneczko wrote:Nice Job! Looks like you even rubbed the firewall heatshield with a rag to buff it up a bit?
Yes, I did. Now its time to get out the toothbrushes....
Current Volvos:
2004 C70 HPT (wife)
1998 V70 GLT (son)
motor1947
Year and Model: v70
Post by motor1947 »
Be careful with water and coils. They don't mix.
fazool
Year and Model: S60, 2007
Post by fazool »
I know this is an older thread but someone asked about engine cleaning today and this was referenced as suggested reading. So, in order to keep everything cohesive I added my thoughts to this older thread instead of the newer one.
the 50/50 armor all mix is a great idea. I usually spray AA directly on after a good cleaning, but I like the mixing idea.
One cautionary note: Keep the Armor All away from your seperntine belt, alternator, etc. You don't want that surface polish on the belts, pulleys or fan motor.
dbm123's engine compartment looks amazing.
If your engine compartment is really neglected you will need some harsher cleaning. But if you want to maintain it and keep it looking like the above picture, regularly cleaning will work with milder cleaning. I use Simple Green. Its more environmentally friendly and much less harsh. I warm my engine slightly, turn it off (so there isn't air rushing around), spray Simple Green all over and especially on the dirty parts. I let this soak for 10 minutes, then restart the engine and blast everything with my power washer using the gentle wash nozzle.
Then I go back and spray all the electrical parts (not the motors or alternator) with WD-40 (its a water displacer, first and foremost). Then I spray my Armor All on and give it a wipe-down.
2007 S60 2.5T AWD (Daily Driver)
2001 S60 2.4T (Daughter's Car)
2003 S80 2.9 (Son's Car)
1995 850 2.4 (Daughter's Car - sold off)
2005 S40 2.4i (Bought new - since sold)
1986 740GLE 2.3(First Volvo - sold off)
fazool
Post by fazool »
I made a 1/3 mixture of Armor All and water in an old spray bottle. Instead of my prior technique or spritz and wipe, I doused everything (except parts which shouldnt be sprayed obviously) and let it air dry. The results were terrific. The sheen was a little uneven until after a full day and some driving - which dried everything out evenly. There is no stickiness.
This is my 11 year old, 142000 mile engine compartment
