Timing belt and water pump = MISERABLE SEVEN HOUR ORDEAL!
This topic is in the MVS Volvo Repair Database » 850 Turbo Timing Belt, Water Pump Replacement Marathon
volvodoc
Year and Model: 01s60
Post by volvodoc »
cam timing marks are located on the inside of top cover when marks are lined up ft cam line should be aprox 11oclock and rear gear aprox 1oclock never never loosen the bolts on the vvt hub
LamboSE5
Year and Model: Empty
Post by LamboSE5 »
Thanks thecheat.
cn90 wrote:For the serpentine belt tensioner, no need to buy the IPD tool or using coins etc. Here is the $1.00 solution.
Great, resourceful idea.
cn90 wrote:3. Grind opposite sides of the plug threads flat with either:
- Bench Grinder
- File (yes you can file by hand)
- Belt Sander (turn the belt sander upside down for ease of use).
-Angle grinder..?
thecheat wrote:You can do that fairly quickly if you turn the vise a few degrees till you get resistance, wait a moment, turn again, repeat until it's back in. I suppose some sort of hydraulic goo is in there that needs to squish back in through a baffle or something.
Ohhh, you must have the hydraulic tensioner right? I bet that is why I was so confused as to what you (and Ozark Lee's Timing Belt Writeup) were talking about.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Crazy, that's the same serpentine belt tensioner tool I made. However, I screwed my plug into another plumbing fitting that gave it a hex. Here is the pic from my write-up:
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
@ rspi: screwing on the hex fitting so the tool matches up with a standard wrench size - so simple and so much cleaner than grinding. Nice!
@ LamboSE5: thanks for bumping the old thread, would not have seen this gem from rspi! :D
SpeedyPete
Year and Model: S70-T5, 1998
Post by SpeedyPete »
Hi guys: IPD has a serpentine belt tool that works great for $29.00. The wright tool for the job will not only save your knuckles but will also save you frustration=Time. I figure if i'm doing the job I want things to go as smooth as possible. This tool can be used on other makes and models. Best Regards, SpeedyPete
Post by erikv11 »
Or, you can walk into any Harbor Freight outlet and get the same tool IPD sells for like $12, and pay zero shipping charge.
The plumbing parts run for about $4 total, work perfectly, and can be picked up even in my small town in Iowa. For me that's the point - I like cheap and easy. :)
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
It's all about the TT$ Ratio (Time To Money) :wink:
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
SpeedyPete
+1 Regent :D I like to buy things from the sponsors of this site. It's my way of helping Matt out. Best Regards, SpeedyPete
LamboSE5
Post by LamboSE5 »
erikv11 wrote:@ rspi: screwing on the hex fitting so the tool matches up with a standard wrench size - so simple and so much cleaner than grinding. Nice!
No problem :lol:
I was thinking the same thing. The other week when I inspected the engine running without the serp. belt (I have a thread) I borrowed an awesome serp. belt tool from a local garage - it ratchets in both directions.
I was trying to think how I could turn this pluming DIY tool into one that would fit into a ratchet instead of just a thumb wrench or vice grips. Why, cause that's cool. :D
What did you screw it into rspi? I don't want it to become too "wide", if ya know what I mean.
Post by erikv11 »
regent wrote:It's all about the TT$ Ratio (Time To Money) :wink:
so, since the plumbing part takes the same time to use, takes less time to get when you need it, and costs much, much less ... :D
