s701998 po172 119,000
Retired MVS Contributor
A further check on BSR's website says "injector cyl 1, sig too high"...A wild guess of a signal that is too high is that it is an open circuit, therefore no voltage drop present...jerrymcc wrote:po172 cross references to ECM-0162 in PPC= "Injector=cyl 1"
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
Is this a turbo model? I know that smell, and it's from oil leaking on the turbo/exhaust manifold from mine from a clogged PCV system/bad oil cap seal.
Lift out the oil dipstick while the engine is running (and warmed up) and see if there is smoke puffing out of the opening.
'98 S70 T5
2016 Chevy Cruze Premier
- 500 Views
Last post by RigsPGT
- 1768 Views
Last post by hermechanic
