I'm hungry
Going to make mac and cheese - be back in a while
Oxygen sensors for S70
JDS60R
- Been thanked: 3 times
Still searching
here is the removal procedure for your vin - notice the square plugs
99 s70with B5254S DENSO oxy sensor removal.pdf- (53.13 KiB) Downloaded 232 times
Retired
Thanks so much for all your help! You truly went above and beyond in helping me today.
Should have known I would have a model where I have to spend more on one Denso sensor than on the two Bosch sensors I bought. Can you please help me confirm that the correct rear sensor is Denso 8627202? What are your thoughts on replacing the rear sensor if I only have a code for the front one? Some of the posts I read say always replace both sensors if you replace one.
Thanks again...
Thanks again...
