I have exactly the same problem. Oil in the water header tank. 97 1.9 td. Took it to volvo and they charged me 60 quid to tell me it 'might' be the head gasket, oild working it's way up the head bolts or the oil cooler.
They suggested changing the oil cooler first as it was the most obvious and easy to do.
v40 1.9td blowing smoke Topic is solved
alfonzobonzo
- Year and Model:
Anonymous wrote:So now I'm looking at doing the head gasket. However the gearbox just went so now just thinking of burning it and flinging myslef on top...
480 L 1994 2.0 i Metalic Black K&N Panel
V40 W 2000 1.9 T4 Metalic Black
1998 V40TD.
On idle, it seems to hunt after a while, revs rise and the engine shudders. Then the blue smoke comes.
The Lambda warning signal comes on (surely a misnomer on a diesel...).
The car hesitates ever so slightly, but power does not seem to be down. No oil consumption, new glow plugs 10k ago, serviced 200miles ago- oil, oil filter, fuel filter, air filter. And yet it still does it! Only 500 miles ago, the MOT tester said he was amazed at my clean emissions.
There is no oil/ coolant mixing as far as I can see.
Please help me.
Please help me.
To test your injectors-
wear goggles and thick gloves, as high pressure diesel gets squirted out at you.
1 remove the engine cover.
2 start the car
3 set the car to fast idle ~1100 rpm
4 slacken the fuel line union nut on the top of the injector- hold a cloth over the union to catch the squirted fuel
5 do this to each injector in turn
6 the injector that reduces the knocking noise or blue smoke when it's supply is interrupted is the knackered one!
TA DA!!!
I thank you.
You may also wish to block of your EGR.
2 start the car
TA DA!!!
I thank you.
- 3395 Views
Last post by jonesg
- 1745 Views
Last post by difflock54
- 2033 Views
Last post by 90 Beater
- 2765 Views
Last post by IVIUSTANG
- 1984 Views
Last post by jimmy57
