As much as i hate to use this link, here is a write up that may help you with what your trying to do..
http://volvospeed.com/vs_forum/topic/86 ... t-comment/
how to acheive 300 WHP ?
- phils94850
- Year and Model: 2009 s60 turbo
1996 Platinum Edition
flyfishing3
- Year and Model:
bugsbunnies95_850t wrote:ok so is a 16t turbo gonna cut t ? or do i need to get the 18t ?
i can only think of one person that made 300 on a 16t. that has to be the max.
18t/ 19t or the kkk24 will get you there easier.
only thing i'm going to say about the IPD stage 3 is get the aqua mist also.
bugsbunnies95_850t
- Year and Model: 99 v70R
what is this about boot spikes ? the 18t and 19t seem to be having this problem and can bend rods.. this snt one bit appealing .. can you she light on what to do to avoid this and what causes it ?
- phils94850
bugs as far as bending rods that usually happens when you get high boost, bigger turbo, at low rpm's. A bigger turbo flows just as much air at lower boost than a smaller turbo with higher boost. understand ? Basically a bigger turbo you need to turn the boost down but you will be getting more flow.
JRL
- Year and Model: Several
- Been thanked: 16 times
This is becoming a bit silly, question after question.
CALL IPD
TALK with them about their stage 3.
They know what to do, they also know the pifalls (a couple of blown engines along the way)
Talk with Lucky or Scott
If you want to get a true 300 hp with reliability, you're going to need to completely build your motor with stronger rods and pistons
There's also a guy on Swedespeed who built a powerful stage 3 engine.
His first one blew, the second one seems to an all mighty, powerful, reliable engine
(He drives it every day), he's not a kid and went through all of this very methodically)
His screen name is Rsterns
Go to SS, do a search for posts started by him.
You will see the entire build, this was from about 7 months ago
CALL IPD
- phils94850
I dont mind the questions keep em coming
as info.. IPD's stage 3 kit is at cheapest 2600.00 bucks
bugsbunnies95_850t
hink i get it .. so basically as longas idont set my mbc at a really high pressure and work my way up to where i want to be i should be ok ?
flyfishing3
- Year and Model:
i wouldn't dare try to wiggle up to 300whp by using only a MBC on a DD.
you need a tune, inj. etc.
like Jim said. it takes money, time and understanding.
JRL
You do NOT use an MBC on a built engine unless everything is built around it PROPERLYbugsbunnies95_850t wrote:hink i get it .. so basically as longas idont set my mbc at a really high pressure and work my way up to where i want to be i should be ok ?
So I have a question. If I wanted to upgrade my turbo from the 15g to a 19t I would need to install some type of boost controller or should it be able to work off of the ECUs controller
Mr. 1000
1995 850 Turbo: IPD ECU, Big Bore intake and throttle body, Volan and cold air intake
2002 996 TT (X50) K24s, tuned to 500+ WHP
2003 GSXR 600 40th anniversary
2008 BMW 750 Li
2009 GSXR 1000: Full exhaust, K&N, PC5
2009 Cadillac EXT : 6.2/ 441 hp no need to tinker
2008 BMW 750 Li
- 5825 Views
Last post by biohazrd76
- 975 Views
Last post by oragex
- 1043 Views
Last post by Ben850
- 2251 Views
Last post by sleddriver
- 76 Replies
- 11478 Views
Last post by MadeInJapan
