S60 fires then stalls
jimmy57
- Been thanked: 320 times
yep, the 4th is fuel temp.
You may have blown a fuel pump fuse, fuel pump died, or the pump electrical module has died or has terminal corrosion.
Ck fuses
bump on bottom of tank while someone cranks it over
check PEM on forward right side ledge of fuel tank
Ck fuses
Ok, all fuses are good. I pounded on the tank while turning it over and nothing. I couldnt get the the coupler apart (yet). Now, this is wierd. My friend stops by who is an electronics guy.He is checking cam sensor,fuel sensor and connectors with a meter and we dont know what combination of things happened,but I turned the key and it started. I let it run for couple mins and shut it off. Turned key and it started and ran for 10-15 secs and started stumbling and died.Turn key again and back to original problem.
