1998 V70 Fires once only on each start, won't keep running
lloyd48
Year and Model: v70,1998
Post by lloyd48 »
Have replaced fuel pump, filter, injectors, got good fuel pressure at union before injectors. Have replaced crank movement sensor, cam sensor & now computer - but still only gives one fire. It does keep running on aero-start - so something's locking the fuel off. Any thoughts ??
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
Based on the work that you have done it pretty much must be the injectors. Check the green wires on the injectors for battery voltage. You can also do the feel test on them, if you touch them you should feel a pulse when the injector fires.
mikealder
Year and Model: V70 2000
Been thanked: 13 times
Post by mikealder »
Clean the contacts on the immobiliser aerial which you will find located around the ignition barrel, the firing then dying after one second is a classic symptom of this, if you have a code reader scan the car, if its the immob aerial it will have set a code of P1670 but this doesn't put the check engine light on - Mike
Post by Ozark Lee »
That was my first thought but the '98 cars don't have a chipped key, at least the US spec cars didn't.
mikealder
Post by mikealder »
UK ones do and I think the Aussy ones also have the chipped key so it's worth a look see if it has the immob aerial fitted, if it's present clean the connectors - Mike
lloyd48
Post by lloyd48 »
Thanks guys, yes this one does have the immobiliser ring around ign barrel - I've had it off & cleaned connections, still no go - any suggestions of how to by-pass this ?? - - 4 wires going into it - red is live / also key doesn't have buttons so what activates what ??
Rbaratt
Year and Model: 850,S70,C70
Post by Rbaratt »
I am looking at a wiring diagram and I was wondering if you could tell me the colors of the other three wires?
2008, C70, 44,000 miles
2000, S70, GLT, 67,000 miles
1995, 850, GLT, 144,000 Miles
1996, 850, Turbo, 226,000 Miles (TMU)
Post by Ozark Lee »
Unfortunately there isn't a quick bypass method. The immobilizer communicates with the ECU via a digital pulse train rather than a simple closure. On the earlier cars it was easy, just jumper a couple of pins in a relay socket and it was defeated, but our lives are much better now with better digital technology.
