It really depends how you drive.
I notice they grip better right off when wet, don't fade over lots of downhill driving, and don't make nearly as much dust as the OEM pads.
front brake pads on an 850
Replacing Volvo Front Brake Discs & Pads
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
'98 S70 T5
2016 Chevy Cruze Premier
boosted5cyl
- Year and Model: '98 V70 T5, '99 S80
instarx what you posted is not quite true. Brakes must dissapate the kinetic energy stored in the drivetrain before the wheels lock (not that that is desireable) or at least approach the limit of traction. Larger/more efficient braking systems mean that this condition is met sooner.
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
bobsnow100
- Year and Model:
Couple other tips
Make sure car is supported on jack stands.
15mm socket or box wrench needed to remove the 2 rear caliper bolts . They are on tight. I use a breaker bar to loosen then and then my socket wrench
I use a strap or rope to support the caliper, once removed you will need to hold it up to keep the weight off the the rubber brake hose. I usually tie it up the the spring strut.
You can also just put a bucket upside down next to the caliper and rest it on it. Just keep the weight off the hose
Caliper grease for the sliding pins.
If you had you brake reservoir up to the full level before the job you will need to remove some brake fluid because when you squeeze in the caliper it will raise the brake fluid level . Brake fluid will take the paint off the car.
Also sometimes I use a flat file just to clean up the rust where the brake pads push in
jblackburn
Remove the cap from the brake fluid reservoir before trying to push the caliper pistons back in. I find that my little floor jack works quite well for pushing the caliper piston back in to fit the new pads; there are other things you can use as well, like a large C-clamp.
If your fluid is old and disgusting-colored, enlist a helper to help you bleed the braking system (or, for $50, you can buy a Mitivac system to make quick work of it by yourself). You must be very clear with said helper to NOT under any circumstances let the brake pedal touch the floor of the car - I usually wedge something behind it so they can't.
'98 S70 T5
WoodrowStar
- Year and Model: 95' 850 turbo
sorry for the delay. i just finished that pad and rotor job today, saved about 250. everything went smooth, so thanks to everyone who offered advice. till next job.
- 14 Replies
- 3904 Views
Last post by instarx
- 2373 Views
Last post by cork5695
- 952 Views
- 2280 Views
Last post by fishingdad101
- 1802 Views
Last post by jlh3rd
