Power Steering Boot
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Re: Power Steering Boot
Post by MoVolvos »
cn90 wrote: 21 Sep 2024, 19:22 For those who replaced the steering boot in the past, what is the easiest way to do this?
The 2006 S60 (or any Volvo in the Midwest exposed to salt) usually has seized tie rods where the INNER meets the OUTER...
Can you slide the boot from the inner side of the outer side if you don't separate the 2 parts?
I have found it best to replace both the inner and outer tie rod to replace the boot when the tie rods have seized. Since I do my own alignments the inner tie rod shaft must rotate in the outer tie rod female end.
