Exhaust Flex Pipe Leaking
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
misha wrote:I just replaced mine flexi pipe few weeks ago.
You need:
-100mm(length) X 67mm(outer diameter)or 61mm inner diameter of flexi pipe(Bosal,Walker,Mafex... it's up to you)
-exhaust manifold gaskets ( 5 of them)
-metal gasket for joint between cat & flexi pipe
Exhaust manifold needs to go out if you want it to be welded properly.Cut off the old flexi pipe and weld in the new one.
Don't cool down freshly welded flexi pipe with water,take your time and let it cool down naturally,otherwise,it will develop little cracks where it is welded.
Install exhaust manifold & joint with new gaskets and you're done.
In the USA, I can only get Scan-Tech Flex Pipe ($60) which includes the 4-bolt flange.
I don't know where I can get Bosal,Walker,Mafex Flex Pipe.
Post by cn90 »
Ozark Lee wrote:It should bolt up just fine but you will need to plug the EGR hole and do the SAS delete with a couple of diodes. SAS is a total waste of time and money anyway. The gaskets were fine and they have not leaked at all.
Lee I have the SAS system.
I'd like to keep it stock (emission testing etc.).
Is it possible to tap into the OBX header for the SAS system?
Post by cn90 »
Here is my manifold, you can see the EGR, does anyone have the solution for the OBX?
Is it possible to install an adapter so the EGR can fit in there?
This is the picture of my exhaust manifold:
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
cn90 wrote:Here is my manifold, you can see the EGR, does anyone have the solution for the OBX?
Not exactly. You were right the first time - that is an SAS valve hooked onto your exhaust manifold. Your car has SAS, it does not have EGR. The solution has already been posted - you need to talk to a welder, either someone at OBX or someone at a local exhaust shop.
Post by cn90 »
Thanks Erik,
My bad, upon closer look the OBX already has the bung for the SAS (RED circle)!!!
OBX here I go LOL:
Post by cn90 »
Last question before I order the OBX.
Anyone here with long-term success with the OBX: 3 years, 5 years, 8 years?
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
cn90 wrote:...In the USA, I can only get Scan-Tech Flex Pipe ($60) which includes the 4-bolt flange.
You can get them from e-bay,there is plenty of flexi pipes with various length & diameter.I googled a lot before i found what i need.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
The bung you have circled is for EGR, not SAS.
Post by cn90 »
After some more research it appears to me that:
#1. Flex Pipe + Muffler Shop labor = $150
#2 OBX part alone = $210....but further research results in mixed result: some are happy and some are crappy LOL. the Honda people hate OBX Flex for whatever reasons.
I finally gave in and order the Volvo OEM Exhaust Manifold from Waltrip Volvo in Tennessee for $360 + $15 shipping (plus gaskets :$35 for 5 +1 gaskets) because:
- I know the OE Exhaust Manifold will fit.
- I know the OEM Exhaust Manifold will last at least 10yr/100K, and I plan to keep this thing for another 8 years or so.
- And if I need the cat later, I can use something like Bosal and it still fits to the 4-bolt arrangement.
After all, $400 is not that bad for something you only spent every 10y/100K miles.
Still better than a car payment!
Credit2u
Year and Model: 1998 V70 XC AWD
Post by Credit2u »
I think I need to go the flexi-pipe only route. Has anyone found a vendor that carries just the flexi-pipe with the four bolt flange, gaskets, etc. for a '98 V70XC (Turbo AWD) in the United States?
Thanks,
-- Grant, Poulsbo, WA
