Manifold Flex Pipe Exhaust leak looking for Ideas please?
plumsmooth
Year and Model: V70 Wagon 2004
Post by plumsmooth »
I just failed inspection and I have noticed my Wagon getting louder and louder over the last year gradually.
In fact the other day right before my inspection it got even louder :roll:
Now I smell Exhaust and i know where it is coming from!
I would really prefer to come up with a master-patch-plan for Flex Pipe...
And put off replacing the Exhaust Manifold until further notice...
It is obviously not worth welding if you have to take the Manifold off to do it.
Maybe some Titanium Header Tape and three hose clamps and stainless zips ties.
Maybe some high temperature rated GOOP :oops:
Anyone please?
I noticed someone used to make (i think someone still does) a weldable replacement flex pipe for this situation!
But can't seem to find one in U.S>
plumsmooth
Also, I am wondering if there is any reason why a flex pipe and some muffler clamps wouldn't do the job?
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
plumsmooth wrote:Also, I am wondering if there is any reason why a flex pipe and some muffler clamps wouldn't do the job?
I think you can do this...
This is the official DIY flex pipe repair
https://www.matthewsvolvosite.com/forums ... hp?t=39723
I'm headed to a local muffler shop Tuesday next week to see what they say and how much it'll cost to do everything from the flex pipe on back. I'm guessing (hoping no more than $300). But really thinking about just getting a stainless steel header off eBay and rolling the dice...
Try it out and see what happens. I love our P80, but this flex pipe/manifold all-in-one is a real pain...
Retired:
2015 Volvo S60, T5, 85K
plumsmooth
Thanks I have read the thread... Seems there are lots of ideas left unexplored, like High Temperature Silicone, Titanium Tape with Stainless Zip ties or Hose Clamps? Also Being that the Flex Pipe can be accessed from the top and bottom maybe it can be done without removing the Manifold.
Because let's face it that defeats the purpose. I can order a complete Manifold Kit for 160 including all gaskets and hardware...
IT wouldn't make sense to have it welded by taking off the Manifold?
Therefore there must be some other ideas?
To me the main issue is sizing the differential between the inside or outside of the manifold port and the Catalytic Pipe Feed?
Am I wrong? Because for that matter why couldn't one just get some flex pipe and clamp it down on two sides? I mean we are taking about connecting two pieces of pipe here. How difficult should it be?
theWIFES_S70
I think you can DIY weld with the manifold in place, if you take off the exhaust manifold heat shield.
I like how you're thinking!
I could see two larger diameter flex pipes cut down the middle, layered over one another, wrapped in titanium tape and held together by a dozen or so stainless steel zip ties working...
Would love to see a picture of that...
Retired:
plumsmooth
Yeah it seems you can do half from the top and half from the bottom (pun intended)...
As far as the Titanium Header Tape, one could almost pull it off from the top (no lift -- pun Not intended)...
I wonder if WE could combine High Temp Silicone Gasket Goop with the Titanium Tape and Securing Hardware and get 5 years plus?
The point I am making is if one's lower manifold's connections to engine is good, why replace the whole thing for one measly rusted piece or holes in flex pipe that should have been Stainless Too begin with!
theWIFES_S70
I agree totally. I'm in worse shape though: the cat and muffler are pretty shot. And when I rev past 3K rpms the engine sounds really bad, like there's something preventing the car from breathing. I just need to spend the (hopefully) $300 now and get to work on it sometime in the Spring when I have more time... I know, it's spending money twice. But I just don't have the two-three-four days to dedicate to it and to all the unavoidable hiccups that might (most likely) arise. Please post pictures!
Retired:
plumsmooth
Has the Volvo had a PCV replacement yet?
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
Find a replacement downpipe and cut weld the cat on.
Anything else is going to fail inspection and emission.
85 GLH, 367 whp
00 Insight, 72 mpg
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
plumsmooth,
Of course you can buy dealer Exhaust Manifold but it costs a lot of money.
Search forum for OBX etc.
I wrote the following DIY for my 1998 V70 a few years ago...
DIY: 1998 Volvo V70 Exhaust Manifold Replacement
https://www.matthewsvolvosite.com/forums ... hp?t=40032
