2004 and newer and NO T6s
04 was the last year for T6s I believe
Buy a 2.5T and flash the ECU to get a nice RELIABLE 240 hp
Of course if you add a downpipe and exhaust you can get to (again) RELIABLE 250-260 hp with tonsof low end torque.
Most of the early issues were fixed by 2004
1999 S80 T6
S80 Performance - Can it be Improved?
JRL
- Year and Model: Several
- Been thanked: 16 times
JRL
They're fine (of course a bit slower) but really no different than an late S60AWD...with better seats and more rear leg room
JRL
Other than the brand new 2011-2112 S60?
2004-2007 S60 or V70R's...... by FAR
Of course you can build up many of these to be very decent, but (almost) stock for stock, the R's have it.
Unfortunately not the 1999-2004 S80T6 because of the transmissions
JRL
No 6 speeds available just the 6 speed automatic but the 2012 S60T6 is one hell of a car
Go test drive one
Go test drive one
I'm about to start the same upgrades with my 2004 s80 AWD. Tell me how it goes and good luck! I'm gonna contact a volvo specialist in the next week so i can tell you what i learn if you wanna know.
- June
- Has thanked: 523 times
- Been thanked: 261 times
2004 is the best year from what I understand. 2004 had a face-lift, updated transmission, still has the standard Bosh alternator with built-in regulator. 2005 updated canbus but computer control voltage regulation. Sister had a 2005 S80 T6 as she loved my 2004. My 2004 had one failure from 12/2003 till 3/2016 and that was the wood piece fell off the shifter lever. Volvo replaced it under the factory warranty. 3/2016 109,XXX miles 2 control arms, 2 axles, timing belt. Everything before 3/2016 only scheduled maintenance and wear items. I have spent quite a bit since 3/2016 keeping my S80 in perfect running condition. I am fussy about maintaining my car as I love to press the accelerator to the floor regularly!!!!
All Volvo repair tickets starting 3/2016 are photographed and listed on MVS as Ice White 2004 S80 T6 in the maintenance section.
My 2004 S80 T6 has always had all the power needed. If you are wanting more power? Use Shell premium only, also 5w30 grade oil changing it at 3k mileage. Other grades of oil make the engine sluggish. Also these engines cook oil early. Keep in mind the oil gets hot in the first turbo then cooks in the second from what my mechanic says. My original engine uses no oil in 3K. Also is so quiet when it idles it can't be heard. Remember the turbo rules! Let the car idle at least one minute before shutting down, and if you drove it hard 5 minutes of idle is required to spool down as well as cool down the turbos instructions are in the owners manual. Enjoy your car! June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
There is only one year Prince wrote a song about Volvos……1999
- 887 Views
- 1293 Views
Last post by Volvo S80
- 1830 Views
Last post by precopster
- 12 Replies
- 3417 Views
Last post by CNGBifuel
- 1721 Views
Last post by kosh_al
