Bulb Failure, position light
fazool
Year and Model: S60, 2007
Been thanked: 7 times
Post by fazool »
two S60's.....several experiences with this....
Its most likely a rear bulb. There are several bulbs in the rear clusters and likely you are simply missing one of those. And note: there should always be one empty socket for the rear fog light (do not add a missing bulb to that socket, otherwise it looks like your brake lights are on while driving and it will blow the fuse).
On my other S60, I had a worn/damaged socket in the front and replaced the socket to fix the problem (the light DID light but the extra resistance confused the system).
No, it is not a ECU problem. It is a wiring problem. And an annoying one I agree.
- double check all your bulbs in back
- check/clean your sockets
ALong this line of thought: I had a *weird* light bulb problem. I had a license plate bulb that would go out. I would lightly tap/rap the lens and it would come on and stay on. I replaced the bulb and the problem went away. Apparently the filament was loose inside the bulb and when it got hot it would stay connected
2007 S60 2.5T AWD (Daily Driver)
2001 S60 2.4T (Daughter's Car)
2003 S80 2.9 (Son's Car)
1995 850 2.4 (Daughter's Car - sold off)
2005 S40 2.4i (Bought new - since sold)
1986 740GLE 2.3(First Volvo - sold off)
MNM
Year and Model: S80,2000
Post by MNM »
Many thanks for this, I will replace some of the sockets I know look bad because the DLR is making them so hot
MNM
Post by MNM »
Thanks for this, I will change some holders I know look very bad especially the licence plate one at the back and see what happens
MNM
Post by MNM »
Quick question guys, following my error message on the bulb failure issue, I've been investigating and wanted to ask if this may be the problem; I fitted front fog light and had them connected directly to the headlight because to use the fog light switch requires a software. The fog lights works ok but could this be causing the error message? Any ideas?
lotus4s
Year and Model: 2000 S80 T6
Post by lotus4s »
It shouldn't since the position bulb is in the rear but disconnect the fogs and see. Hope you're running the fogs off a relay and not directly off the headlight wiring....
2000 S80 T6
1995 Lotus Esprit S4s for sale
http://sites.google.com/site/jkesprit/
2007 Toyota Tundra
