Hideous vibration after renewing engine mounts
Marcobrick
Year and Model: 2003 V70T5
Has thanked: 3 times
Post by Marcobrick »
Mounts might be a red herring. The vibration seems almost entirely to be transmitted via the steering rack as after some investigative driving, I can't feel any through my feet but the steering wheel buzzes a LOT. Should I be checking the rack attachment bolts? I think there are 5 but where exactly are they and are they tough to get to?
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
1973 Land Rover Series 3 flat deck.
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1995 850 Turbo Wagon
1998 V70T5
Favourite line: "How hard can it be?"
D_V_ENT850R
Year and Model: 850R 1996
Post by D_V_ENT850R »
One from IPD. Non poly,
RustyH
Post by RustyH »
Marcobrick, I have also been thru the motor mount and vibration nonsense. I was insistent on figuring out why my wife's 2000 S70 nonturbo vibrated at idle. I had both the lower hydraulic mounts changed after I changed the one by the crank, top and torque strap. I bought non-Volvo mounts from IPD. Big, big mistake. The vibration was much much worse and I regretted ever having gone down this path. I finally purchased one Volvo brand and one Hutchinson brand (I believe they are OES) for the two hydraulic mounts and that solved the problem other than inherently more vibration from a 5 cylinder engine as opposed to my smooth inline 6 in my BMW. So, if you by any chance used after market mounts, you may want to replace. I have also seen JRL mention that several times in my internet searches. The rear hydraulic mount for my vehicle also comes with a metal washer looking thing that sits on top of the mount. I suspect that Volvo learned that this rear mount needed more height. Perhaps you need that thing???
Marcobrick
Thanks for the reply. This is now someone else's problem as the car is now sold! I have purchased a 98 V70T5 7-seater. I will be much the wiser when it comes to buying parts for this one.
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
URO crank mounts transmit far more vibration than stock; readers beware.
Fish stick88
Year and Model: 1994 - 850 Sedan
Post by Fish stick88 »
If the old mount is still usable, i'd suggest putting it back in, often times over 10 or so years, of constant back lash the engine will push and pull on that joint, bending it a little, the new mount, would have made it stiffer, and would cause the vibrations to go throughout the metal cage of the car
Speed has never killed anyone, suddenly becoming stationary... That's what gets you.
'94 850 Sedan - 160k miles
Marcobrick
Fish stick88 wrote:If the old mount is still usable, i'd suggest putting it back in, often times over 10 or so years, of constant back lash the engine will push and pull on that joint, bending it a little, the new mount, would have made it stiffer, and would cause the vibrations to go throughout the metal cage of the car
The rubber in the old mount was broken clean in half. Yes, I did sin and fit a URO crank mount. The only place the vibration manifests itself is through the steering wheel. It is not nearly as bad now as it was when I first changed the mounts. The new owner picks it up tomorrow and as soon as he is gone I am going to get my new (old) V70.
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
