Exhaust Leak, 850, Real Loud Now.
I have a 1997 Volvo 850. I'm having a continuing exhaust leak at the catalytic converter - muffler connection. The converter was replaced because of a PO429 code and that problem was solved.A new clamp was used and the muffler pipe was still in good shape with no deformation or was not too rusty.
Now we just can't get a seal at this junction. We tried a new clamp, and then the Bosal clamp after the new clamp didn't solve the problem. We then replaced the entire muffler, and still have a leak at this junction. The 1997 doesn't use a gasket at this joint like the earlier years did. How do you get a seal at this junction
Not an expert on this, but I would just go pick some exhaust sealer stuff that they sell at any autoparts store (putty or tape) and do what you can to make it a tight fit.
It sounds like you are close and may just have a small hole. Seal it with something made for sealing exhaust holes, may just not line up perfect.
1993 Volvo 850 (w/97' engine in it)
- 2262 Views
Last post by matthew1
- 14 Replies
- 2612 Views
Last post by EngineeringBloke
- 14 Replies
- 3831 Views
Last post by DeathRex
- 2205 Views
Last post by Dreadvolvo
- 2309 Views
Last post by hanacaptain
