V70 XC Cross Country: P0136,P0445,P0448,P0245,P0135 & P0037
lancechapin
- Year and Model:
What power supply are we talking about.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Alternator/battery charging system. You should see AT LEAST 13.4V at idle, around 14 with no load on it and the engine around 2000 RPM. Anything less, either your alternator is down on voltage or the battery cables are becoming very resistive and not letting enough current through (this is a common problem with these models).
'98 S70 T5
2016 Chevy Cruze Premier
Xilikon
- Year and Model: 2000 V70 XC SE
Random misfire even with good spark plugs and ignition coils will generally lead to two other possibilities : Bad fuel ignition system (doubtful since there are o2 errors which mean there are fuel getting past the engine and into the catalytic converter) or bad power system (alternator/battery and main wiring like the positive and ground cables).
2000 V70 XC SE with 150,000 miles, still going great !
lancechapin
- Year and Model:
Update-
Thank you for all of the support. I removed and cleaned all the grounds to the engine. Retaped all coil wires. left battery disconnected overnight. Cranked car up this morning and same codes reappeared.
PO445
PO448
PO245
P1655
PO031
I checked the alternator- 13.5 with a/c on, bright lights on.
It seems as if the engine is shaking like a misfire but without those codes present.
Any suggestions on where to go from here? Thanks again for all the help. Lance
PO445
PO448
PO245
P1655
PO031
lancechapin
- Year and Model:
I am also finding out that my expensive laptop will not read or communicate but my cheap scanner will.
lancechapin
- Year and Model:
Anybody have any suggestions on what step I should do next. I cant afford to take to Volvo. I am a service advisor for Toyota. The techs there are willing to help but not sure where to go. Any help is GREATLY appreciated. Lance
voltage drop B+ cable under load at 2000K rpm with fan on high lights on and rear defroster. this is cable that goes from batt to fusebox
https://www.matthewsvolvosite.com/forums ... =1&t=35208
99 V70XC 158K
95 850glt 188K
95 850glt 188K
- 1834 Views
Last post by bmdubya1198
- 12 Replies
- 3045 Views
Last post by DanielV
- 1375 Views
Last post by URDRWHO
- 825 Views
Last post by RickHaleParker
- 2243 Views
Last post by MrBreeze
