Throttle Body Cleaning
This topic is in the MVS Volvo Repair Database » How To Clean Volvo Throttle Body
850oldschool
Year and Model: 1996 850 NA
Been thanked: 45 times
Post by 850oldschool »
Is it safe to say that if the TB is gummy there may be a sludge problem elsewhere?
callahanoffroad
Year and Model: 1995 850
Has thanked: 16 times
Been thanked: 53 times
Post by callahanoffroad »
850oldschool wrote: 09 Aug 2020, 14:13 Is it safe to say that if the TB is gummy there may be a sludge problem elsewhere?
It's typically just blow by from the pcv system. Potentially it could also be oil from the turbo. Or oil from the crankcase. Give it a scrub, then check your PCV system and your turbo (if you have one). :-)
Author, Chef, and Shade Tree Mechanic
1995 Volvo 850, Non-Turbo, VVIS, LH FI, Green, 215,000 miles. B5254FS engine. Herman. viewtopic.php?f=1&t=84393
1996 Volvo 850, died at 280,000
Founder of: CookingForChemo.Org
Read my Silly Comic Book at: therealpizzabros.com/
Has thanked: 1610 times
Been thanked: 4065 times
You are typically supposed to clean TB and PCV on 50,000 mile intervals.
It’s normal to get oil residue in the hoses and TB especially on a turbo
FLXC90
Year and Model: 98 V70 T5
Post by FLXC90 »
To remove the cable, using one hand, spin the throttle quadrant (pulley like thing) towards the windshield, with your other hand, guide the cable off to align with the slot in the side of the quadrant, and pop it out.
Current Volvos:
You can unclip the rod that couples the accelerator cable to the throttle body, loosen the Four M6 10mm hex head screws and remove it fir cleaning.
Disconnect the electrical connector if needed.
You will need a new throttle body gasket, too
Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 77 times
Been thanked: 59 times
Post by Cookeh »
abscate wrote: 10 Aug 2020, 18:03 You will need a new throttle body gasket, too
Volvo 9135990, circa £4 in the UK. Presumably similarly cheap in the US.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
A gummy TB gives no reason to suspect a sludge problem. Clean it up. Be sure not to get solvent into the TPS.
