Don't happen to have the climate control on defrost?
My car is low on a charge and when left on defrost, the compressor cuts in and out and causes a slight RPM fluctuation like that.
Very minor issue but I'm stumped
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
'98 S70 T5
2016 Chevy Cruze Premier
JRL
- Year and Model: Several
- Been thanked: 16 times
No ideajimmy57 wrote:Does it have the shallow sump angle gear and no vibration damper fitted?
I am unsure of that detail on 99's. I can't recall when the deep sump appeared and damper was omitted.
I have the same cyclic throbbing on my 98 that is shallow sump and has the stud head bolts for the damper to bolt to but no damper. I have done all three mounts which made everything else better but actual brought this on. Or maybe the new mounts took away the other harsher stuff and let this be felt.
Techron AND Seafoam, no changerspi wrote:I was thinking that maybe your knock sensors were tweeking the timing. Toss some octane boost in it or run some 93 for a tank or two and see if it changes.
l always run the AC manually, so nojblackburn wrote:Don't happen to have the climate control on defrost?
- Has thanked: 311 times
- Been thanked: 818 times
Well are you going to check?? You have our interest now ...JRL wrote:No ideajimmy57 wrote:Does it have the shallow sump angle gear and no vibration damper fitted?
How you use the AC is not relevant to his post - he asked if the defrost is on. We all know you are expert in these cars, but still your response suggests you are not aware of this: If the dial is set to defrost, then the climate control will turn on the AC if/as it determines AC cooling is needed (for condensation purposes, yes even when it is cold).JRL wrote:l always run the AC manually, so nojblackburn wrote:Don't happen to have the climate control on defrost?
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
I have the same issue on my '98 V70 5 spd FWD.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
JRL
Of course it's not on defrost, I really don't think I needed to clarify that
- E Showell
Anjill182 -- what did you do to address the computer issue?
'95 855 auto (sold)
'95 855 auto (sold)
burnout8488
- Year and Model: 1999 S70 AWD
Mine will do this too, as if something is turning on. Check to see if the fan or compressor are engaging, regardless of what the ECC is set to.
Does it do it when the engine is cold AND hot?
'13 BMW X1 35i M-Sport
'99 S70 AWD/FWD - 198K - FOR SALE!
- Has thanked: 2864 times
- Been thanked: 1332 times
Everyone: I deleted some posts. Please stay on-topic and don't be afraid to start new topics if it's warranted.
JRL: no need to be prickly. They're just trying to help. You're frustrated... with your experience with the P80 this must keep you up at night.
- 1921 Views
Last post by 93Regina
- 448 Views
- 562 Views
Last post by vtl
- 24 Replies
- 4527 Views
Last post by bmdubya1198
- 586 Views
Last post by 2012
