I spent over $3K on suspension work/RF wheel still knocks
I had the exact same problem and ended up replacing the springs, struts, sway bar and links, and tie rods in an attempt to get rid of the clunking sounds. When I pulled the struts apart I checked the strut mount visually and tried to twist the bearing and everything looked ok. I put all the new parts and in took it out and...still there. I thought I would give the struts mount a try since it was relatively cheap and fixed everything. Give it a try and start with the cheap stuff first if you don't what the problem is. Good luck.
I had this problem. This was exactly the solution for me as well....
wheelsup wrote:I had a horrible clunking sound in my front end up by the strut tower area, and also the LF end link, but they were separate issues.
I replaced:
Strut mounts (3)
Sring Seats (5)
Bump stop (7)
Dust boot (9)
Strut (10)
Sway bar end links (one of mine was bad, but I did both) (11)
Parts, OEM Sachs except for the Meyele HD sway bars, was around $400-$450 give or take IIRC. This fixed my clunking in the front end. I wouldn't replace the shocks as they are pretty much a lifetime thing, they don't tend to wear out unless they rust away.
I think, but just a guess, 85% of the clunking in the front ends are due to worn spring seats (5) and bad sway bar end links (11).
Current Volvos:
2004 C70 HPT (wife)
2002 S40 1.9T (daughter)
2001 V70 XC (daughter)
1999 V70 GLT (now dead)
1998 V70 GLT (son)
The other car: 2003 Saab 9-3 SE Convertible (mine)
2004 C70 HPT (wife)
1998 V70 GLT (son)
update:
Come to find out that the mechanic just needed to add more axle grease to everything and the "knock" went away. we came to the conclusion that the axle and hub needed more grease. that's all. I was all pissed off for nothing.
thanks fo the replies and advice anyway.
98’ S70 T5 Turbo Manual - Midnight
01' S60 T5 Turbo- Brandy
98' V70 T5 Turbo - Swifty
93’ 244 n/a - Mr.Chill
91' 940 SE Turbo - Mojo SOLD
83' 242 DL - Bluto SOLD
93' 940 Wagon - Django - SOLD
samsson101
- Year and Model: 95 850 GLE
My money would still be on the strut mounts. With the car sitting in the driveway , with the bonnet up, bounce it as hard as you can , and you will hear them knock
