PO305- cylinder 5 misfire
s70glt novice[Will]
- Year and Model: s70 glt 98
Re: PO305- cylinder 5 misfire
Okay. I believe its the injector...
I got the turbo in (2 days of UGH) and the tune. started up, lots of blue smoke. fearing bad things i turned the car off. turns out i just had to let it run for a couple minutes.
anyway, the problem is now consitent to over 10 psi. if i go up to 10, i sound like a harley. its also related to engine speed. but the psi seems to have the most effect. 16 year old injectors+ 17 psi of boost= not enough fuel.
point is, what do you guys think?
'98 s70 GLT-127k
ARD Green, obx, 16t, other go-fast parts
s70glt novice[Will]
current codes are, po245, po 130, po135, po141, po136, and po305
the emissions ones are from when i broke the tube to the ptc valve >.> i also dont have the SAS hooked up. nor the rear o2.
*EDIT* ill upload a video of it happening today
'98 s70 GLT-127k
s70glt novice[Will]
you can slightly hear the studdering, it got better so maybe some junk came off.
'98 s70 GLT-127k
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
Misfire is from not enough fuel or not a strong enough spark.
Have you changed plugs? What are you using? Gap to .026" for that much boost.
'98 S70 T5
2016 Chevy Cruze Premier
s70glt novice[Will]
okay. i did think of the spark plug... the cheap gapper i used fell apart on the last plug. i'll re gap and see if that helps. the boost is probably blowing it out. it also got slightly worse. it now comes at 3.5k and ~5-7 psi. im guessing from the plug getting burnt or something bad from being blown out. ill check on them tomorrow. thanks for all the help!
'98 s70 GLT-127k
jblackburn
You may want to shell out the $$$ for Volvo plugs on that. I've never used them, but I'm not sure how well standard plugs like Bosch coppers hold up to high levels of boost.
'98 S70 T5
s70glt novice[Will]
Im using Bosch Platinums. I heard that turbos dont like iridium plugs. I hear that those are what the car likes best. And we all know if you just open the door wrong, the CEL comes on until you apologize. I dont like using cheap parts, especially for crucial components like the sparks plugs. I really hope this works, i cannot wait to feel the full beast my car has become.
'98 s70 GLT-127k
jblackburn
What!?!?!? Get that crap out of there!!! These cars HATE platinum plugs - well known across any Volvo forum.
Bosch Super Copper or Volvo OEM plugs only.
'98 S70 T5
s70glt novice[Will]
Well okay then. I'll switch them out soon. how much do you think a set of volvo plugs are? I'm assuming they are better then the Super Coppers, so will they hold up to the added boost?
(Off-Topic)
I've also seen commercials for ion plugs, that pretty much shoot lighting (ionized particles, small difference) into the cylinder. They do not have the "rod" to which conventional spark plugs spark to. The temperatures of these ions are also higher and spread out through the air (more even burning?)
Think volvos will like them?
(Off-Topic)
'98 s70 GLT-127k
s70glt novice[Will]
Also, since i have a misfire on cylinder 5, are the cylinders counted from the camshafts or the distributor cap?
'98 s70 GLT-127k
