Hard Pull 1998 C70 T5 = smoke from vents
s70glt novice[Will]
- Year and Model: s70 glt 98
check out FCPGroton: http://www.fcpgroton.com/product-exec/p ... gory_id/64
'98 s70 GLT-127k
ARD Green, obx, 16t, other go-fast parts
- cmblackburn
- Year and Model: 1998 S70 T5M
- Has thanked: 1 time
- Been thanked: 7 times
Whatever you do, don't use the URO system. It's a piece of leaky, unrefined crap that we ended up having to replace after only about 40k miles. The hoses don't fit properly, and it's very poor quality.JxKenny wrote:Id the 137$ for the ipd PCV kit my best bet? Or is there a cheaper alternative that i should use?
http://www.fcpgroton.com/product-exec/p ... gory_id/63
When you are in the final stages of buttoning it back up, the elbow that goes into the side of the intake by the computer box loves to be a troll and pop off. If you need to, put a small clamp on that. Otherwise just be mindful of this, that simple little hose can make this whole job seem to have done nothing by not allowing vacuum to the system.
Good luck!
1994 855 Turbo, 243k "Honey Badger"
1998 S70 T5M, 287k "The Blue Turd"
2004 S40 2.4i, 197k "Cosmo"
2005 XC90 2.5T AWD, 207k "Apollo 13"
2011 VW Jetta SportWagen TDI 6MT, 93k "Zoe"
jblackburn
- Has thanked: 9 times
- Been thanked: 20 times
Call them up and ask they substitute all OEM Volvo parts for your order.
'98 S70 T5
2016 Chevy Cruze Premier
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
I think this was for me Jblackburn. I'll take a look as there is now coolant and oil drips side by side on the drive way.jblackburn wrote:It's easy on a front-wheel drive model and will take you about 30 minutes to replace the gasket - if even!
Here's a post on the matter. There's some pictures I put up in the linked topic in the first post.
https://www.matthewsvolvosite.com/forums ... =1&t=41451
- 1180 Views
Last post by difflock54
- 734 Views
Last post by 93Regina
- 12 Replies
- 7403 Views
Last post by kippster41493
- 1011 Views
Last post by regent
- 962 Views
Last post by volvolugnut
