Try cleaning the sensors on your front wheels. Once you get it jacked up and the wheels off, it'll take you 15 minutes for both sides.patrioty3k wrote:Haven't cleaned the sensor on the wheel yet,front drivers side,thought my caliper was bad,replaced the caliper,rotor and pads,bled out quite a bit of air/fluid....still getting a grinding noise on the same wheel,seems like the pedal wants to go way down,don't know much about the abs system,not a big fan,i don't have the abs light on,can maybe i disconnect the wire or fuse?this happened probably about 4 months ago,getting worse when i brake at regular speed and when going slow like into a parking lot....any ideas would be helpful.....thanks
ABS/TRACS lights came on... then went off?
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
'98 S70 T5
2016 Chevy Cruze Premier
patrioty3k
- Year and Model: 1995 850 Turbo Wagon
Thanks Justin will try that.....
1995 850 Turbo S/Wagon,Alpine head w/Sirius Sat. Radio--"OCTANE" power!
200K $400 Sleeper...nuff said!
- 22 Replies
- 6154 Views
Last post by hausmeister
- 938 Views
Last post by GreenMagicMan
- 32 Replies
- 9091 Views
- 1135 Views
- 1666 Views
Last post by aaronlife
