flashing red arrow on 850
Thunderbox
- Year and Model: 1998 V70 NA
- Has thanked: 1 time
www.matthewsvolvosite.com/read-codes-volvo-850
Should be everything you need to about reading codes. good luck and let us know the results
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Are you saying that when the gear selector is in "N" the car goes in reversemc4457 wrote:...I'm not sure I aligned it but when I reassembled it it seemed to only go back in one position with the selector in neutral.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Andrew ren
- Year and Model: S70 1999
If it keeps coming back on (the amber arrow/CEL) its the well-known ABS module problem.
- misha
Not on these cars.When abs/tracs module fails it triggers abs/tracs lights.Andrew ren wrote:if it keeps coming back on (the amber arrow/CEL) its the well-known ABS module problem.
Depends of how much it's failing...it can produce intermittent or not working speedometer.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Year and Model: Many Volvos
- Been thanked: 76 times
I'm sorry to squawk but bumping a thread after 2 minutes is a bit out of line. It isn't like there is a huge office building full of highly paid Volvo specialists waiting to immediately jump to your aid. We are all volunteers, this includes the members and even the moderators.
That said, you need to download the factory service manual that is hosted on this site. It is specific to a '95 model but it is equally as applicable to your '94 in every way. The manual is here:
https://www.matthewsvolvosite.com/downlo ... vo_850.zip
Once you unzip the manual and go through the layers of sub folders you need to open and read the pdf file named Auto Trans Diagnosis. There are some tests that you really can't accurately do without a breakout box but many you can.
The manual has a good diagnostic tree for each error code. If the problem comes and goes I would suspect a dirty edge connector on the ECU or a dirty connector going to the transmission.
- 13 Replies
- 2805 Views
Last post by jtmarks923
- 1253 Views
Last post by 95850turbowagon
- 1615 Views
Last post by Cox Abele
- 2306 Views
Last post by Scholz
- 753 Views
Last post by rspi
