Key Programming Tool for Volvo
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
You can program keys with a passthrough device. You must be a locksmith with the credentials and bonding. Getting the credentials is not so easy.You use the locksmith association issued number(LSID) to allow key software purchase via Volvotechinfo.com if you are Chemult OR or whatever site your country uses for this function. Your passthrough device will have to have the OS that supports key programming.
007
- Year and Model: XC90 0406, 2012 C70
forumoto wrote:alright, i will give it a try and see the outcome, if using the chinese clone just as prosper said or use my oem drewtech as well and see what will be the respond, thank you
Hi, can you let me know the result? Thanks.
jenkinskg
- Year and Model: 04 c70 hpt 98 s70 xc
- Has thanked: 1 time
I just saw this on ebay http://www.ebay.com/itm/VOLVO-Diagnosti ... 1714137974?
Myself I have just had dealer make key copies for $35 each, on the s60 I just taped the chip to antenna ring, works great, 2 keys work, no chip in either
on my c70, going to take chip and mount to antenna rung under dash, the use non chipped keys.
Then I can put in remote start if I want
2004 c70 2.3HPT, s60 2.5T
- 1296 Views
- 4217 Views
Last post by stephansvolvo
- 11 Replies
- 17917 Views
Last post by kcodyjr
- 1428 Views
Last post by jenkinskg
- 3000 Views
Last post by forumoto
