A Monster Bolt-On Turbo Kit: Fast Friday #30!
This topic is in the MVS Volvo Repair Database » Monster Bolt-On Turbo in Prototype Phase
RyeZ
Year and Model: 98 C70
Post by RyeZ »
These Volvo 5 cylinders really do respond well to low ambient temps. Portland rarely gets below freezing, but I remember what a difference those really low temps made when I lived in Canada. Only problem was, the colder it got, the less traction the tires got :lol:
As for "size" of the turbo, yes, I was referring to the internal Volume of the turbine housing as well as diameter of the turbine wheel. When talking about "size" of the turbine side of a turbo, two elements are at play. First is the diameter of the turbine wheel, which as you would suspect, affects the cross sectional flow area that the hot exhaust gasses escape through. Second is the A/R of the turbine housing, which is basically the angle of incidence with which the exhaust gasses first contact the turbine wheel. A small A/R (high angle of incidence) means the exhaust gasses need to make a more dramatic change in direction before exiting the turbine housing which causes restriction, but also supplies more torque to the turbine wheel to accelerate the turbo. On the flip side, a large A/R (low angle of incidence) means the exhaust gasses do not have to change direction as abruptly, but also do not put as much torque on the turbine wheel. A small A/R is good for quick spool at the expense of flow capacity, where as a large A/R is the opposite. The TD05H has both a larger diameter turbine wheel, and a larger A/R than the stock TD04HL range of turbos, which explains both the higher rpm performance as well as the freer breathing engine.
On a side note, the S60R that we will be using for prototype testing of the R32 kit will arrive tomorrow morning and install should start tomorrow afternoon. I'll be sure to keep MVS updated!
rzdesignusa.com
c70_lindsay
Year and Model: 99 S70 T5.
Post by c70_lindsay »
On a related note, my credit card company just increased my limit by $4000.........
covert24
Year and Model: S60, 2002
Post by covert24 »
I apologize for reviving this but you stated that this will be available for ALL 5 cylinder P2 engines. I'm just going to assume that means the N/A models right?
KLR142
Year and Model: 1991 244
Has thanked: 5 times
Been thanked: 5 times
Post by KLR142 »
covert24 wrote:I apologize for reviving this but you stated that this will be available for ALL 5 cylinder P2 engines. I'm just going to assume that means the N/A models right?
You could bolt it on, but it won't work. The engine management is different and would likely require many changes, if it's even possible. 01/02 cars are Denso, I don't know about the later ones.
Ps. Lag still matters on the race track... You find yourself waiting for the thing to spool when exiting corners when you really get aggressive with your setup. Something that spools at 4000rpm and above, with a RPM limit of 7000, may not make for as quick of a setup that spools at 3500rpm with the same limit, even if it's down 50+hp!
hyp2bsqr
Year and Model: 850R, 1996
Post by hyp2bsqr »
Rye,
Thanks for putting this together. I have a TD05H-16G connected up to my 740 8V B230FT and it is definitely an impressive turbo. I've employed 3" inlet/outlet plumbing and I find it a bit laggy (3000+ RPM full spool) with an exponential rises in boost when it does reach max. Do you have any updates on inlet/outlet plumbing experiments? And if anyone would like to comment on whether or not the lack of breathing on the 8V head is a significant contributor to lag due to gulping issues that would be great. Here is a picture of the engine compartment Image of this beast. The car is a 120K mile 744 SE that is in all original paint and trim.
Thanks,
Hyp2bsqr
Reason: Fixed image URL.
Fail to plan. Plan to fail.
