In my latest install into just acquired 98 C70, I fashioned a 'pilot bolt' by grinding the tip of the 10 mm bolt to aid in starting the bolt into the block. About 3mm of the tip was ground so that it became cylindrical unthreaded tip that is smaller than the fastener diameter. It helped a lot.
I will start throwing in one of these in the refurbed lines I'm making to help a bit in the installation.
oil cooler lines rebuild
Click me to save $150 on 94-98 Turbo Cooler Lines
* SOLD - 98S70 Blk/Blk T5M B&G/Bilstein, 17psiST, R-mani, 3"dp/obxExhaust, SASdel
* 98 White V70AT GLT'ed - LPT motor swapped
* 06S60 2.5T Blk/Blk - wife's DD
- Has thanked: 311 times
- Been thanked: 817 times
Nice tip. Would bolt that is just a few mm shorter achieve the same purpose? I'm not totally following.orleec wrote:In my latest install into just acquired 98 C70, I fashioned a 'pilot bolt' by grinding the tip of the 10 mm bolt to aid in starting the bolt into the block. About 3mm of the tip was ground so that it became cylindrical unthreaded tip that is smaller than the fastener diameter. It helped a lot.
Made it to sort to look like this:
http://www.google.com/imgres?imgrefurl= ... =200&w=200
- 2153 Views
Last post by fitz548
- 1603 Views
Last post by SuperHerman
- 8206 Views
Last post by Ozark Lee
- 1550 Views
Last post by rguzz
- 16 Replies
- 3093 Views
Last post by erikv11
