99 s70 transmission shifts hard
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Re: 99 s70 transmission shifts hard
Post by jblackburn »
powertrip56 wrote:Ok the fluid Is dark pink and smells bad. I've owned the car for 19k miles..so anything before that old what was serviced on it
Change it in intervals via the "drain-and-fill" method. Remove the plug @ the bottom of the transmission, dump the pan, replace what fluid drains out, and repeat a week or two later 3-4 times.
Volvo v70 transmission drain and fill tutorial
'98 S70 T5
2016 Chevy Cruze Premier
Matty Moo
Year and Model: 850, 1996
Has thanked: 1 time
Been thanked: 30 times
Post by Matty Moo »
99 non-turbo is the 5-speed auto.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
powertrip56
Year and Model: 99 s70
Post by powertrip56 »
mine says D 3 L i thought that is a 4 spd..
powertrip56
another issue i want to bring up.. when im driving, i get a small wheel shake up front. along with that a Clunk / tink noise once in a while, when i hit potholes and stuff in the road, (small ones..) and i realize when i brake, i get a heavy shake.. i was thinking maybe something in the fornt end was loose making it shake while i drive, and make it shake more when i brake.. not shure what it could be?
Matty Moo
Has thanked: 1 time
Post by Matty Moo »
powertrip56 wrote:mine says D 3 L i thought that is a 4 spd..
Odd. Our 99 na is a 5-speed auto.
2000 s70 GLT
2014 Ram
jblackburn
99 was a split year. Later models had the 5 speed (probably those with VVT also).
'98 S70 T5
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
I don't think so
Has thanked: 1507 times
Been thanked: 3825 times
powertrip - I PM'd you
giftvolvo
Post by giftvolvo »
Can the wheel shake and clunk/tink sound he's getting have anything to do with a faulty front anti-sway bar?
