98 s70 t5 hiccup
Ben850
Been thanked: 7 times
Re: 98 s70 t5 hiccup
Post by Ben850 »
.Maybe an oxygen sensor or something that wouldn't be changed out with an engine swap...any thoughts?
Yes, that is exactly what came to mind. The wagon I recently brought home had me baffled. After swapping almost everything that made sense, I swapped both O2 sensors, and that was it.
Also, the Sedan wasn't throwing any codes, but after all I had replaced, I knew something was not quite right. I replaced only the front O2 and it is a whole new car.
It makes sense for you if both engines had the same symptom.
Good Luck.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 111 times
Post by E Showell »
Could be rear sensor, but I changed the front one recently.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
E Showell
Post by E Showell »
Plus, it is not exhaust-leak related since I have a new exhaust system.
'95 855 auto (sold)
m96ag
Year and Model: 2000 V70XC
Post by m96ag »
Did you check the ECT sensor?
2000 V70XC 160,000mi.
E Showell
Post by E Showell »
Been replaced at least twice w/in past 5 years.
'95 855 auto (sold)
m96ag
Post by m96ag »
Did you check the duct that the MAF connects to? The plastic gets brittle over time and can crack causing a vacuum leak. Mine actually broke completely off right where it connects to the turbo when I went to check my air filter.
E Showell
Post by E Showell »
New duct with the engine swap, but thanks for suggesting it. And, indeed, the plastic was badly cracked right where it connects to the throttle body. I am dealing with a non-turbo as well.
'95 855 auto (sold)
m96ag
Post by m96ag »
Have you considered the possibility of it being a drivetrain and not a engine performance issue? Also, does the problem only occur when you are stepping on the brake? If so, you might want to look into the power brake booster and its associated vacuum lines.
E Showell
Post by E Showell »
Hadn't considered drivetrain issues -- such as, for example? Haven't looked at brake booster.
'95 855 auto (sold)
m96ag
Post by m96ag »
Transmission issues can cause hesitation upon acceleration, but I would start with the brake booster.
