V70 Rear Coil Springs
- Has thanked: 1505 times
- Been thanked: 3818 times
Ill tell you in a couple years when i have to do the 2005
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 606 times
I'm not sure, only suspect, but XC70 and V70 AWD rear springs could be easier to replace, because springs are weaker than V70 FWD's ones, which are just monsters. I mistakenly ordered S60 springs and the car sagged down quite a bit. Though I like the ride with softer tail more, car rear end is not bumpy now at all.
vtl
You need something like that: http://www.ebay.com/itm/SAAB-Suspension ... 68&vxp=mtr
But the plate size should be at least 155mm (just measured my old rusty original springs).
Yew I was looking at that one in 1st place but then looked at what this guy used and thought i should go for this instead? The cpa looks very interesting do you realy think this one may be better? My springs have arrived today and now my search for a spring compressor begins! Thanks for all your help!
- GBS
- Year and Model: XC70 2003, V70 2002
Interesting reading, I did the shocks only on our V70 02 and was so thrilled with how easy it was compared to the XC70 03 (where the whole strut assembly has to come out and need spring compressor). Now I hope my rear springs are ok and I don't have to replace them any time soon, ride height seems OK and with new shocks its not bouncing.
Is ride height/broken springs the only indication to replace springs? Ours have 195k now and original springs but new shocks.
What happened with me is I did the front shocks and springs and this has made the back seem very low! Replaced the shocks like you on rear having researched replacing the springs found this forum which has been very helpful indeed now have my new springs but am looking for the right tool to do the job due to lack of space I have come across this Sealy ak3842 and was wondering may this do the Job?
- 2009 Views
Last post by BrianIwasiwkaC30V70
- 778 Views
Last post by Stickit
