1997 v70 Don´t have Heat in inside
Klausc
- Year and Model: 1995 855 Turbo
- Has thanked: 5 times
- Been thanked: 15 times
Please check the temperature gauge in the instrument panel. If it doesn't go to the middle, your engine thermostat may be broken and in the open position allowing coolant to circulate all of the time. The heater core will only get luke warm, not hot enought to produce meaningful heat.
Klaus
djekan
- Year and Model:
- Has thanked: 1 time
Klausc wrote:There are two motors, one on each side. The probability that both of them failed is remote, but a failure would cause the blinking yellow lights of death.
I don't understand, it is not that cold in Germany yet.
Hello,
Yes, there are two motors (picture), and I have checked this to, and both works perfectly.
Maybe the motors are loose from the hedge,
i need remove again the heater core to check this.
Volvo V70 MK1 GLT - 2.0 Turbo - 1997
Volvo 850 GLT - 2.0 TURBO - 1994
Volvo v40 1.6i- 2001
djekan
- Year and Model:
Hello,Klausc wrote:Please check the temperature gauge in the instrument panel. If it doesn't go to the middle, your engine thermostat may be broken and in the open position allowing coolant to circulate all of the time. The heater core will only get luke warm, not hot enought to produce meaningful heat.
the gauge is always in middle, normal temperature.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
You do NOT have to remove the heater core to check the linkage.
Klausc
I think he meant the two heater baffles. They should be working unless he took them off once and now they would be out of position.rspi wrote:You do NOT have to remove the heater core to check the linkage.
Klaus
djekan
- Year and Model:
Not?rspi wrote:You do NOT have to remove the heater core to check the linkage.
then as I see it is sealing well? I think this cover is on top of the heater core, or not?
there is another way to check this?
Thank You!
djekan
- Year and Model:
Klausc wrote:I think he meant the two heater baffles. They should be working unless he took them off once and now they would be out of position.rspi wrote:You do NOT have to remove the heater core to check the linkage.
hummm, I never took the baffles site, unless now to look for anomalies, it is possible to pass from the right position? then both at the same time?
I Will see this tomorrow!
Thanks!
I recently installed a new evaporator core--during reassembly, I reversed the plugs to the damper motors. Got no heat to drivers side, but lots of ac. Fault lights blinked 20 times. Plugged correct inputs to damper motors and everything works (except my brain)!
djekan
- Year and Model:
Ok,
today i can´t see that, in Portugal is raining, don´t have garage so, i need wait for good days
Klausc
Does your instrument cluster temperature gauge work correctly? Put the climate controls on auto vent and auto blower speed, start the car and drive it. The temperature of the coolant should climb rapidly after 1-2KM and be at the mid point. If it is still pointing to 'cold' after 5KM, your engine thermometer might be broken and in need of replacement.
As to the damper motors for the heat/AC, if the kick plates are removed next to the gas pedal, you should be able to place a finger on the motor and feel slight movement when you turn the temperature down and up. Do not take the damper motors off, that could make things worse.
Klaus
- 455 Views
Last post by wisewoman
- 403 Views
- 1556 Views
Last post by Orchid Girl
- 600 Views
Last post by Flyingdutchman
- 4784 Views
Last post by wizechatmgr
