Code: Select all
Powering the SRS system
Warning! Nobody should be in the passenger compartment when the SRS (supplemental restraint system) is first powered after fault-tracing/repair.
Caution! Ignition off during the entire procedure.
Reinstall the connectors, components etc.
If the battery negative lead has been removed: Connect the battery negative lead.
When powering up the SRS-system, other systems and components in the vehicle will also be activated.
Power the SRS (supplemental restraint system) by clicking the VCT2000 symbol.
Performing the service may take up to 30 seconds.
