I checked the vacuum lines before reassembling the intake manifold. They all look good.
Here's a video I just uploaded
Let me know what you think guys!
Thanks!
1997 850R rough idle after head rebuild
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Hmm. It actually sounds like it's running ok, aside from the top end being clicky from not having built up pressure. I think your MAF is fine - it's not bogging and choking like it would if that or a major air hose were loose.
Is the throttle position sensor plugged in? If not there, how bout the air lines to the idle control valve - any holes?
'98 S70 T5
2016 Chevy Cruze Premier
are you positive you didnt mix up two or more of the plug wires on the distributor?
RIP: My Father 10/17/13 The Spiegel Grove claims another Soul.
"We are all the sum of our choices. The fear is not of dying... it is to not have lived."
Forever loved. Never Forgotten.
renzo86
- Year and Model: 00 S80 T6, 04 S60R
I was just messing with the intake bolts. A couple of them were not tight enough. So now the engine stays running longer but stills runs like its choking. Like it needs more air. I also hear a weird knocking noise where the idler is.
jblackburn
It just sounds to me like the hydraulic lifters haven't built up pressure yet.
It kinda sounds like it's firing at the wrong time...it runs fine on a couple cylinders, then sounds like it slows down for a second.
Are these all right?
'98 S70 T5
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
Even if the wires are at the corresponding numbers, a plug may not seat over the pin firmly. I would use dialectic lube and re-seat.jblackburn wrote:It just sounds to me like the hydraulic lifters haven't built up pressure yet.
What is the make of plugs, rotor, wires, and cap?
- 2237 Views
Last post by 93Regina
- 1639 Views
Last post by PagodaMomar
- 991 Views
Last post by Ozark Lee
- 1094 Views
- 23 Replies
- 6410 Views
Last post by precopster
