2004 V70 NA - Wheel Alignment question
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
The attached PDF how & what items to measure and the tool required to put it all back into place...
Spring and seat replacement S60.pdf
(299.51 KiB) Downloaded 483 times
dejongmc
Year and Model: 2004 Volvo S80
Post by dejongmc »
Thanks for all your help so far.
Attached the alignment numbers I received from the NTB technician after the alignment was done for the 2nd time within 2 weeks. (the first time they didn't center my steering wheel)
He said that it is not possible to adjust the camber on these cars. Only trucks.
V70 Alignment Report.pdf
(96.63 KiB) Downloaded 141 times
1997 850 NA Wagon - 261,000 miles - Is no longer
2004 V70 NA Wagon - Saved my life
2004 S80
precopster
You should have shown him the attachment I provided.
He is so full of it that he will unfortunately never get your alignment to spec without changing the upper pivot point.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
I had bad experiences with alignment shops... (not Volvo). The tie rods bolts were seized and they were saying they did the geometry. Not saying yours is dishonest, probably they simply don't want to do it or cannot get a good measure for some reason.
precopster
Why does your report point out CASTOR? This is DEFINITELY not adjustable.
Can't read your camber setting. The PDF is not clear
