There are 3 different solenoids (SLS, SLT & SLU) and 2 different kits. 2003 and on for valve bodies marked "B" and "C" have their own kit.
The other solenoids S1 through S5 are not targeted. They just need to be tested.
The Sonnax part numbers you listed are for single solenoids not kits. Kits are sold on eBay.
Then the other solenoids for valve bodies with no markings or marked "A"
Both 2002 cars I refurbished were marked "A" as well as my uncompleted 2001.
Be careful with solenoid sellers. Some eBay sellers such as ctpowertrain mention the letter designations and some don't.
Also replacing just the solenoids is a shortcut which should fix 90% of the issues. In my video I show 2 small piston valves which I had already replaced. These solve some minor issues.
Also replacing all the valve body gaskets will solve minor cross leakage between oil galleys. Before embarking on this journey read all the literature I've provided including the Transgo install instructions.
2000-2008 AW55-50SN Valvebody re-assembly
2001-2007 AW55-50SN Valve Body Re-assembly
precopster
- Year and Model: Lots
- Been thanked: 128 times
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
That's a great video. Can I just remove the SLS, SLT and SLU solenoids without opening the valve body? I'm thinking I'd only replace the solenoids at this point.
precopster
It's certainly doable, only 2 bolts keep them in. Testing the remaining 5 solenoids is also possible without removing the valve body. However placing the SLT, SLU & SLS solenoids back on requires fiddly alignment which would be very difficult if the VB was still attached.oragex wrote:That's a great video. Can I just remove the SLS, SLT and SLU solenoids without opening the valve body? I'm thinking I'd only replace the solenoids at this point.
Removing the valve body isn't such a big deal as it's only 6 x 10mm bolts. Just lift the engine around 1.3 -1.4 inches instead of the recommended 1 inch as this makes all the difference. Just clean the mating surface gasket before placing it back on. No need to disassemble the valve body layers.
- oragex
Yes, I will remove the valve body from the transmission, just didn't want to open it. The gasket to the transmission is to be replaced, or just have the surface cleaned?
precopster
The gasket to the transmission forms one of the deepest gaskets in the assembly. I would just clean it and be sure it doesn't get damaged in the process. It only contacts the transmission over 7-8 square inches. The rest is embedded in the valve body. Be sure to check the 2 O rings on the transmission before placing the valve body back in place. If they fall off there'll be no line pressure.
- oragex
Great, I'll report back for improvement, I only have a 2nd to 3rd shifting kick, hope it's only the three solenoids.
precopster
Have you checked the B4 cover?
- oragex
No. I will check it as well, however from what I've read the servo cover is more responsible for shifting flare. My transmission doesn't have flare, only harsh (kick) shifting. I'm not sure though, I'll check it as well.
precopster
Harsh kick on upshift is usually not the problem with these.
Usually it's harsh downshift from 3rd to 2nd.
- oragex
I think you are right, is there a chance this could be only software related? If I remember, when I got the car it was shifting well, the issue only started after draining the fluid (with the 3309 one) but I didn't went to the garage for adaptation and new fluid reset.
- 11 Replies
- 4387 Views
Last post by precopster
- 5517 Views
Last post by SuperHerman
- 1757 Views
Last post by BEJinFbk
- 16 Replies
- 14764 Views
Last post by vt9000cse
- 1661 Views
Last post by dadyer
