1996 850 GLT Very Rough Idle
I really don't think it's compression either. Yesterday while driving it, it was completely fine and driving normal; but as soon as it hit that point to where everything was warmed up then it felt like something was holding back it's full potential. First gear pulled alright as well as second, but everything after that felt sluggish like.
florbinginge
- Year and Model: 1996 850 GLT
There are some tricky vacuum lines behind your intake manifold which commonly crack and break. Those would be worth checking if you haven't already. It may be worth checking if your PCV is clogged as well. You can test this by starting your car and removing the oil cap. Put a rubber glove over it and if it blows up the glove, your system is clogged. This happened to me without throwing any pcv codes
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
_
Carefully double check timing.
_
_
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I don't think a clogged PCV system will cause poor performance. Maybe a bad ECT, it can cause a bad fuel mix. Usually poor running after it warms up is ignition parts.
Alright guys here's an update, check the codes again the other day and got the following: idle air control valve stuck open, idle air control valve stuck closed. Put a new iacv on it yesterday, but now it idles too high, so I tried adjusting the idle screw back and now it's not even touching and the car is idling at roughly 1300rpm. Guess I'm gonna replace all my vacuum lines with silicone hoses. Does anyone know where I can get a good vacuum hose diagram at?
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
Does an 850 have the same learn process for the IACV? I think I remember reading that the computer has to relearn things when screwing with the IACV. Something akin to disconnecting the battery for a longish period, reconnecting,, starting the car and let it idle all the way to full warm. I don't know for sure about a Euro car or which Motronic versions this applies to but I'm pretty sure the IACV has to relearn at some point.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
- 533 Views
- 78 Replies
- 12358 Views
Last post by PeteB
- 1412 Views
Last post by cuhfs
- 962 Views
Last post by sweedespeed1
- 644 Views
Last post by MrAl
