1999 Volvo V70 stubborn driver's side axle...
burnout8488
- Year and Model: 1999 S70 AWD
Re: 1999 Volvo V70 stubborn driver's side axle...
Your heat shield needs to be bent back, it's dragging on the rotor.
'13 BMW X1 35i M-Sport
'99 S70 AWD/FWD - 198K - FOR SALE!
- misha
- Has thanked: 152 times
- Been thanked: 402 times
Could be...but it would also rub in reverse and will not stop when brake is applied.burnout8488 wrote:Your heat shield needs to be bent back, it's dragging on the rotor.
Could be a sticky caliper or bad brake disc.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 113 times
- Been thanked: 115 times
...close to 5 O'clock position?Ozark Lee wrote:I use a cold chisel as a wedge.
line it up offset from the center - to the right as you are looking at it - at the back of the inner CV joint.
paredown
- Year and Model: 1999 V70
- Been thanked: 2 times
We have a winner--it was a slight divot on the plate. maybe a misplaced hammer blow?burnout8488 wrote:Your heat shield needs to be bent back, it's dragging on the rotor.
1999 na 2.4l V70 beater--donated to Habitat in running condition
- Year and Model: Many Volvos
- Been thanked: 75 times
Very common. Any time you use a pickle fork to get the ball joint off of the steering knuckle it will inevitably bend the dust shield behind the rotor. Getting the dust cover flattened back out is now part of my SOP when I change out a control arm.paredown wrote:We have a winner--it was a slight divot on the plate. maybe a misplaced hammer blow?
Exactly.xHeart wrote:...close to 5 O'clock position?
- 703 Views
Last post by MadeInJapan
- 15 Replies
- 5080 Views
Last post by matthew1
