Has anyone tried ATF or Lucas or Seafoam as in the thread below?
http://volvoforums.com/forum/volvo-850- ... try-71337/
changed oil, now have lifter ticking all the time
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
- edit -
lies and misinformation were spread here; i will be tarred and feathered in the square on sunday evening, if you're thirsty for vengeance.
- misha
- Has thanked: 152 times
- Been thanked: 402 times
Noj-dawg wrote:if you switch to a heavier-weight oil, i'd expect more ticking.
If you have valve ticking with low weight oil the ticking will go away with heavier weight oil.
Also if the engine burn some oil between changes,heavier weight oil will improve things.The engine will reduce,if not completelly stop,to burn oil.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
+1 Misha
j-dawg
- edit -
ah, we're talking about ticking that doesn't go away, not just at startup. my mistake.
incidentally, am i right about the lighter oils for startup ticks? ie, if i were ticking with a 10W, might i not tick with a 5W?
- Has thanked: 292 times
- Been thanked: 765 times
Many people remedy the ticking by going to heavier weights, I think you're saying it backwards? So, if it ticks with 10w, the ticking will be worse with 5w.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- 3455 Views
Last post by Klausc
- 1504 Views
Last post by RickHaleParker
