2008 S60 2.5t fuel rail removal question
goldxc70
- Year and Model: XC70 2004
- Has thanked: 27 times
- Been thanked: 3 times
Which type of connector do you have? Unless you remove the connector from the fuel rail, you may not see it. It goes into the fuel rail first, the connector goes in after it, and then that is held in place by the same metal piece that hold the injectors in place. Without an o-ring, you would have no seal and I suspect that you would have a major gas leak.
my fuel line has this new clip and I have removed the screw and the clip, and pulled really hard, but the fuel rail won't come out. Do I need the special tool to remove the fuel line from the fuel rail, or can I pry it off with a flathead screwdirver?
thanks in advance!
thanks in advance!
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
From what I remember, once the screw and clip are out, you have to depress or pull another tab on the remaining black piece. Try looking very close maybe with a small mirror.
- 376 Views
Last post by misha
- 16278 Views
Last post by Richard99
- 859 Views
Last post by CSDentonTX
- 1327 Views
Last post by cn90
- 13 Replies
- 3164 Views
Last post by loosenut
