2006 XC70 Vibration when Accelerating
Re: 2006 XC70 Vibration when Accelerating
I tried taking the prop shaft off to drive it around without it so I could see if it's the problem. I got all of the bolts off the front and back joints as well as the center bearing support. I could not get the front or rear joints to separate from the car. Liquid wrench and a hammer. They wouldn't budge. Is there a trick to separating them?
I got the prop shaft off. I took it to a local Volvo shop and they pulled it for $80. Both the front and rear joints are worn and difficult to rotate/pivot. I'm getting a rebuilt prop shaft from Colorado Driveshaft.
There's still a vibration under moderate acceleration. It's improved, but still there. Other motor mounts? The transmission mount/link looked ok. Angle gear? Timing belt? I'm at 127,000 miles and I ordered a timing belt kit.
I don't know if I'm finding and fixing the problems or merely chasing symptoms.
Without the prop shaft, there's a whine when the car is coasting (foot off the gas). Is that expected? I would think - No.
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 606 times
Check support bearing on right axle. Remove carriage bracket, pull axle down a bit, try to rotate bearing with your fingers. Bearing on my V70 was dry - grease has been washed away by time and spilled engine oil. Had it replaced ~1.5 years ago - no whine anymore. Fairly easy to replace if you have a press in garage.
- 2657 Views
Last post by Krons
- 14 Replies
- 3785 Views
Last post by Cees Klumper
