1993 Volvo 850 Reverse/Trans Issue
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Re: 1993 Volvo 850 Reverse/Trans Issue
Post by jblackburn »
alexk243 wrote:The feeling is defiantly due to trans issue and not the engine shifting due to bad motor mounts. are you guys saying the bad mounts can contribute to the trans going out? Or that it may be giving me false symptoms?
Bad mounts won't kill the transmission; they'll just make gear changes go in with a nice thunk or jerk as the transmission is briefly not putting power down.
I would change the fluid again, and maybe once more in a few weeks, and cross your fingers that it gets better. Reverse requires higher fluid pressures to engage, so it is usually the first to go out when parts start to wear or valve bodies clog internally.
Don't use ATF additives in the AW50-42, just stick to clean ATF.
'98 S70 T5
2016 Chevy Cruze Premier
timmybdaddyof3
Year and Model: 1998 V70 T5
Been thanked: 2 times
Post by timmybdaddyof3 »
The valve body's clogging can sometimes be solved with a good flush, but again, if you are thinking about taking it to a shop make sure that you trust them and they know what going on - a bad flush can cause early death.
Just to clarify, when I said additives I did not mean off the shelf autozone crap - there are friction and viscosity modifiers that Aisin Warner lists as acceptable for certain issues.
alexk243
Year and Model: 1993
Post by alexk243 »
If the trans goes, how hard is it to replace the trans? Is it doable in a personal garage? Cost?
1993 Volvo 850 (w/97' engine in it)
