98 V70 AWD Coolant System Failure - Turbo Fried
shegarty
Year and Model: 1998
Has thanked: 12 times
Been thanked: 8 times
Re: 98 V70 AWD Coolant System Failure - Turbo Fried
Post by shegarty »
jblackburn wrote:Fix the coolant lines first and see if it still spins/boosts.
If not, pick up a used turbo at a junkyard. Check it for play - if there's little-no horizontal play, stick it in the car and don't worry about it.
+1 on this advice. I pulled the turbo off my 94 850 before scrapping it and it was not an easy job. All the fittings will likely be rusted/stuck and some are in very awkward positions. Do the easy part first and see what happens you might just save yourself a lot of work and headache.
98 S70 T5 SE 298k km (daily)
87 740T sedan (current project)
previous - 90 745T; 94 855 T5
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
Pulling turbo off a 850 is easy. You should try pulling a turbo on a 80's turbo dodge, head has to come off!
85 GLH, 367 whp
00 Insight, 72 mpg
shegarty
Post by shegarty »
tryingbe wrote:You should try pulling a turbo on a 80's turbo dodge, head has to come off!
of course it does ... it's a Dodge :) says the guy who has owned a Dakota and now a Caravan.
quadzillabill
Year and Model: 1998 V70 T5 AWD
Post by quadzillabill »
Well, things got worse. I was hesitant to let the original place do the work and after talking to another mechanic he convinced me to bring it to his place to make sure the head gasket wasn't blown. We got it over there and he was able to fit some temporary cooling lines to do a short test run with water. Low and behold, the head gasket is shot as well. Good thing I didn't throw $1200 at the turbo.
This same guy will do a used engine install for me for roughly $750 and it seems that finding something decent with a bit lower mileage might be a reasonable way to go. What are some good sources for a salvaged engine?
Has thanked: 1503 times
Been thanked: 3817 times
Southern Volvo and Erie Volvo .....just look up at the banner ads
tryingbe
Has thanked: 1 time
Post by tryingbe »
85 GLH, 367 whp
00 Insight, 72 mpg
mecheng
Year and Model: 1998 Volvo S70 T5
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
I inspected my turbo coolant hose, it is bulging. I bought all the hoses and washers, will install soon.
I'd recommend everyone to have a look this.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Has thanked: 292 times
Been thanked: 765 times
Post by erikv11 »
Actually there are two of them, check (and likely replace) them both.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
mecheng
Post by mecheng »
erikv11 wrote:Actually there are two of them, check (and likely replace) them both.
Yes, I bought both but only the hose adjacent to the turbo is bulging a bit on both the 850 and S70. I noticed that the screw clamp can't be accessed from under the car, I will try from top or try turning it.
Year and Model: 2004 V70 2.5T
Been thanked: 471 times
Post by cn90 »
@mecheng,
Actually you can access the clamp from below. The key thing is to get a very long screwdriver (I have the 16-inch long screwdriver, $8 at hardware store, or Sears) and push on the clamp to turn it so the screw faces you.
All the tips/tricks are below. BTW, use Volvo OEM hoses only!
DIY: 1998 S70 GLT Turbo Coolant Hoses and 2 Radiator Hoses
https://www.matthewsvolvosite.com/forums ... hp?t=55306
