1996, 850 Turbo, E-Brake Adj. Issue
Re: 1996, 850 Turbo, E-Brake Adj. Issue
And there it was!...the upper part of the retaining clip is indeed held on with a 13mm cap screw. I had first looked at the bottom hole and thought that the clip was riveted to the backing plate. I now see that this is just a bent tab that holds the bottom of the retaining clip. I will get new hardware tomorrow. I am also going to order some new cables from FCP to see if that helps with my original problem.
2008, C70, 44,000 miles
2000, S70, GLT, 67,000 miles
1995, 850, GLT, 144,000 Miles
1996, 850, Turbo, 226,000 Miles (TMU)
I went to the dealer and purchased new shoe retaining clips along with the springs over the adjusters. After installing the new hardware, I was able to complete the brake adjustment without any of the binding I was previously experiencing.
I inspected the e-brake cables and could not find any visible signs of cracking or binding. The parking brakes are now adjusted and working, but I am still experiencing a single snapping noise after releasing the brake and accelerating forward.
In a different discussion thread I found a comment that mentions a "pop" can be considered normal on these cars. Here is the comment ----" the Volvos allow the shoes to float, slide, even rotate quite a bit making for a less robust "emergency" brake while moving and highlight the need to make sure they are centered on the backing plate then re-adjusted after a couple uses to account for any repositioning of the shoes from "re-settling." As such, don't be surprised if you hear a "pop" when applying the parking brake if the car is trying to roll the opposite direction from the last time it was applied -- shoe rotating a bit in the drum until they hit the stop on the other side
Not sure if they are describing the same snap that I am experiencing, but for now I will run it until something changes.
