That's a good rule of thumb (toe?).abscate wrote:For most people, putting a foot onto the factory wrench will over torque the lugs. It's better to under rather than over torque. They have to be grossly under torqued ( 10 FT lbs or less?) to come loose.
04 XC70 Replacing front pads and rotors
2004 XC70 -- Replacing Brake Front Pads And Rotors
- Has thanked: 2861 times
- Been thanked: 1332 times
- Been thanked: 4071 times
Rule of heel and toe? Tap dance?
Here are the torque specs for the caliper bracket
http://www.volvoxc.com/0/resources/how- ... -discs.pdf
and not a perfect answer, but this will get you in the ballpark
http://www.volvoxc.com/forums/showthrea ... nut-torque
For reference, caliper bolt torque listed above is 100NM or 73 foot pounds
The rotor screw is only 8 Nm, or only about 5 foot pounds...that's basically hand tight.
- osman
- Year and Model: 2002 c70 hardtop
He-he torque specs. Other than when I am doing a head gasket repair I never use a torque wrench. It is an advantage to doing your own work but I will tell you this: The size of the bolt determines the torque its that simple bigger bolts need and can handle more torque. After working on cars for years, we just know how tight things are supposed to be. Torque wrenches are normally very long meaning they are not practical for MOST applications. I have worked in shops and like I said unless its a head, no one even knows where the torque wrench is located. So in other words if you have ever had your car worked on by practically ANYONE, they did not use a torque wrench. I'm just saying. Torque specs can be important in some aplications like suspension and steering, etc but putting a universal adapter on it makes the reading wrong because some of the torque is being lost. So often they are not used because they just cant fit in the particular space you are working.
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
99 XC70 AWD LPT 115
- 2269 Views
Last post by fishingdad101
- 1585 Views
Last post by befarrer
- 22 Replies
- 3020 Views
- 700 Views
- 15 Replies
- 4071 Views
Last post by polskamafia mjl
