Also, you could check for excessive current draw by the starter motor during cranking - this will create too much flux which will 'jam' the signall from the CPS (crank position sensor - it is quite close by and not well shilded). At the same time, the excessive load on the battery will pull the system voltage down a bit lower down than normal. (This is a known no-start with a seemingly working starter.)
Try to see if you can measure the draw while cranking.
1996 850 Has spark, compression, fuel, won't start
- regent
- Has thanked: 2 times
- Been thanked: 12 times
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
Here's what it does without the plugs in the cylinders, just sitting in the plug wells.
Won't let me post the video I took.
The car does fire, shoots a small flame up from each cylinder for about 10 seconds of cranking, then stops.
If I put the plugs in and try and start it, it sputters briefly and then nothing. If I put my foot to the floor and hold it down it will not catch.
precopster
- Year and Model: Lots
- Been thanked: 128 times
You could have low compression due to cylinder walls no longer being lined with a film of oil known as "lawn mower syndrome"
The fix to restore compression is to place a teaspoon of oil in each cylinder. This restores compression and allows a start. While the engine is running, the splashed oil from crank counterweights allows cylinder re-lubrication.
If you measure compression before and after there is always a marked difference and also the starter will slow down as it encounters a higher load.
- regent
Silly question here, you already know yor valve timing is fine. Your ignition setup is with a distributor cap. Can you doublecheck your firing order - this is all that remains: two or more plug wires are most likely crossed. Been there, done that.
Happy Fourth!
Happy Fourth!
2015 BMW 335i
2015 BMW 335i
Atis
- Year and Model: S70 GLT 1998
- Has thanked: 1 time
- Been thanked: 4 times
Just thinking loud and throwing in ideas...
Maybe your sparks are really not at the correct timepoint. Cam sensor can cause such a thing as well, although in that case you should have a code for that. Maybe somehow the ECU thinks that your sensor is OK not throwing a code.
With my previous car I had a similar issue ('85 Ford Orion), there the "amplifier" of the ignition system went wrong and although I had spark at the correct time, fuel and compression as well, but the spark was too weak. Oh and the real nasty thing was that as I have changed the ignition coil just as a trial, it killed that and after that when I put a known working amplifier in, it still did not worked because of the died coil...
Oh and one more. Did you checked the fuel pressure while cranking or in steady state? Maybe you have good fuel pressure in a steady state, but if you have a "blockage" in the fuel line, as soon as there should be fuel flow, your pressure is dropping.
Yes, we did check the pressure while cranking. Dropped a little, but not a huge amount. I'm beginning to think that the cam sensor failed. All the other threads seem to indicated that in order for the code to show up, the car needs to be running, and this one is not. I do have a couple of salvage yards reasonably close, with lots of inventory to pick through, might be worth a trip this afternoon to go get some cam/crank sensors and just start swapping stuff out....
- Year and Model: Many Volvos
- Been thanked: 76 times
If the cam sensor fails you won't get spark. As I have glanced through this thread it sounds like you have everything you need to have a running engine.
One thing that comes to mind is that maybe you are flooding. If the fuel pressure regulator fails it can suck raw fuel into the intake manifold. Are the spark plugs wet when they come out after you crank it?
- 26 Replies
- 4418 Views
Last post by momentumbob
- 49 Replies
- 10891 Views
- 12 Replies
- 2072 Views
- 3120 Views
Last post by Roger_850T
- 17 Replies
- 2729 Views
Last post by Dingo957
