01Volvo V70 XC Transmission fluid fluctuates
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
draser
Year and Model: 2005 S60 2.5T
Been thanked: 2 times
Re: 01Volvo V70 XC Transmission fluid fluctuates
Post by draser »
Basically the oil level reading on dipstick may vary due to oil temperature, car being on flat surface, etc. So long as you're in the cross hatched are you're okay. The other thing to keep an eye on is coolant level in the overflow tank on the left. If coolant goes low make sure tranny oil level is good and oil does not look soapy. Volvo radiators seem to suffer from rupture issues.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
Penny0322
Year and Model: V70 XC 2001
Post by Penny0322 »
Thanks guys!
I just got my new Servo cover in the mail and it is the new up-grade cover (guaranteed.)
I am going to attempt to install the new Servo cover tomorrow and it did come with specific directions. I am also going to drain the trans again and refill, and will take your advise,"not to use the Seafoam."
After all this, I will try and find an independent shop to check to verify if the TCM has the latest firmware version upgrades.
I still suspect that my trans fluid is over filled and will take some out before driving, because I would rather it be under filled, then over filled. I will drive it for 30 minutes and let it cool down for 30 minutes, park on level ground and check the level with the stick curved down.
It is the independent shop that makes me nervous! Because when I took it to JR's Volvo in Louisville Ky. The mechanic told me that I need a new trans, but after I paid $650.00 for a new timing belt and water pump. When I took it to the shop it was just slipping a bit from 2nd to 3rd and when I drove home it was shifting horribly in every gear! He over filled the transmission fluid to way above the hot! After I drained that out, it then went back to sifting better, but still slipping from 2nd to 3rd.Can you guys recommend a qualified mechanic in Bedford Indiana, Bloomington or Louisville Ky, but not JR"S Volvo?
I will let you guys know how it all goes, again thank you and wish me luck!
Penny0322
Post by Penny0322 »
Also, do I need to reset the fluid counter via Vida after changing/adding to fluid, if I drain it and then just re-fill?
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Ideally it would be better to reset the fluid counter after 3-4 drain and fills.
Also after B4 cover best to reset adaptives and do the drive cycle as you'll notice that shifting may be worse after a new servo cover.
Vida is also needed for this.
Fluid temp must be over the set limit to begin the cycle (when the limit is reached in drive cycle mode the info display will say FLUID TEMP HIGH)
The drive cycle begins with 1,400rpm shifts in 1, 2 & 3 and 4 followed by down shift by coasting to stop.
Next is a 1,800rpm cycle with shifts of 1, 2, 3 & 4 then again coasting to stop.
Finally a 2,500rpm cycle with ALL gears including 5th being reached followed by coasting to a stop.
The aim is to find a VERY flat unoccupied peace of road in order to avoid the tailgaters. When an ideal upshift is reached a warning hazard triangle will flash momentarily in the display. The trick is to get one warning hazard flash for each shift in each rev range including downshifts which you only need one set of from 80km/h to rest.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Penny0322 wrote:Thanks guys!
For the transmission oil, you can try the Valvoline Max Life Transmission oil (at Walmart), some people seem to say it works a little better, and is cheaper than the Mobil 3309 or Toyota T-IV oils.
